Bill & Brendas RV-8 QB
RV-8
Elevators
5-18-2011
Trim tab hinge
Measured and placed hinge in the trim tab, double and triple check alingment, clamped in place
Match drilled the hinge through the skin
Drilled the bottom side of trim tab through the bottom flange of trim tab spar
Dimpled the trim tab skin top and bottom
Dimpled the bottom flange of trim tab spar and counter sunk top flange of trim tab spar
Marked the inboard edge of pian hinge to be cut off flush with skin and spar
Aft trim tab hinge drilled and clecoed in position
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
