Bill & Brendas RV-8 QB
Date:  2-23-2011
Number of Hours:  9.00
Brief Description:  Front HS spar and rib work
Relief holes for bend in front hs spar
dimple front spar and countersink reinforcement bars and bend the spar to 6 degrees to match the reinforcement bars
edge break and smooth, deburr holes of the 10 ribs
flute ribs
drill HS spars to angle bars and main ribs. First mistake happened here! Drilled hole to close to edge of reinforcement bar after drilling through the main rib flange and and spar web. Stopped here to call technical support in morning to see if part should be replaced.
Flutted ribs
Flutted ribs
Top angle bar mis drilled-first scrap
