Bill & Brendas RV-8 QB
Date:  7-23-2014
Number of Hours:  0.50
Brief Description:  Torque rear spar bolts and cotter pin.
The rear spar bolts are to be torqued to 100-140 inch lbs and then cotter pin. my bolts first needed to have a 3/32 drill run thru the cotterpin hole in the bolt because the hole was too tight.
I then had to work the washers so that I could achieve proper torque and get hole to line up in castle nut. This process has been numerous times during the build and isnt anything new.
Left side 3 reglar thickness washers used and right side was two regulkar and one thin.
Got pins in and bent over and cut off exces with wire cutters.
Installed my stainless steel pitot tube and cover
Rear spar attach bolts torqued and cotter pin
Stainless steel pitot tube installed.
