Bill & Brendas RV-8 QB
RV-8
Sanded the epoxy down on all the rivit holes in sk
Sanded flush the epoxy micro filler on the zillion skirt riviyt heads. Used a block of wood with paper glued on.
I also sanded to a nicer fillet around the canopy latch handle tube.
There are several areas that require another dab of filler and then sanding before I spray on sanding primer.
Canopy latch handle tube fillet sanded
Sanded the micro down on all the skirt rivit heads
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
