Bill & Brendas RV-8 QB
RV-8
Cabin heat box control final
Drilled hole in angle brace near the heat control box for the control cable to fit
Picked a spot on shelf brace to add an adel clamp and drilled for a #6 Counter sunk screw and attached to brace securing cable.
Added a cable clamp to the heat box mounting bolt that clamps the outer sheath to keep it from slipping during operation.
Pulled the inner wire out far enough so I could cut off the excess cable sheath.
pushed inner wire back fwd and cut off excess just beyond the attach point at lever.
Smoothed the edges with grinding stone and attached the actuation wire with supplied hardware.
Works but I need to trim off another 1/2 inch from outer sheath for a smoother non binding operation.
Cable hooked up to cabin heat door lever
Routing of cabin heat cable on fire wall above rudder pedals
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
