I realized that some circuit breakers were needed in my panel and i didnt make provisions for their placement when I laid out the panel. So..... I decided to remove one of my dimmer pots and use that hole for one cb and then lined up another on each side. Drilled holes up with the unibit. Came out nice. Im not excited about the placement of them but I can live with it. I also drilled for a 4th cb on left side apron. This is for the trim servos and just happens to be near the trim indicators. That works ok for me. A bit odd in placement but I figure if it pops I wont have trim adjust and will be able to easily reset if need be.
Impromtu location found in panel for some circuit breakers.
trim circuit breaker in left apron near indicators
