Brief Description: Canopy skirt left side drilling-2
1. Started off by extending intersecting lines down on to the skirt upper row and then drilling with undersized drill and follow up with 1/8 unibit. Had trouble lineing up with a few holes but managed to get them adjusted for fit.
2. Moved on to the lower row and used the hole finder and Drilled #40. These will need to be updrilled to #30 and then all countersunk. The lower row begins an angled row with about 5 holes up to the top row. Only could reach 2. Need to make a template for the other 3.
3. Clecoed on my 3 rib templates and drilled the holes for the ribs.
