1. Lightly took the edge off the previously drilled pilot holes. Probably not necessary since they will be drilled up to at least 5/16 later but...
2. Put some painters tape around the canopy just above the drilled holes. I will put some intersecting lines on the tape that will help in locating and transfering hole locations on the skirt later
3. A friend and kit logger Mike Smith brought over some 1/4 od 1/8 id silicone RC fuel line that I will possibly use to protect the holes from the rivit. Thanks Mike!
