Bill & Brendas RV-8 QB
Date:  5-13-2012
Number of Hours:  1.50
Brief Description:  sanding of hs and vs tips
Sanded the tips so that they would fit properly and that the elevator would swing up and down w/o hitting. Im not sure if I need more clearance than this so I need to hold off on rivitting them in place for now.If I were to re do this, I believe cutting the tip about 1/32 under size of final gap desired and then building it up. I can still sand the center portion to make a slight concave end and that will also provide more clearance. Ill be comming back to this
Left hs tip and the nice fit to the rib
The VS tip with slight gap that may need a fillet later
Left HS tip and the elevator tip gap. Tight but not hitting. Might need to work this more
