Bill & Brendas RV-8 QB
RV-8
VS tip and rudder upper tip
Marked and cut to fit the VS fiberglass tip and sanded for fit the Rudder upper tip
Cut aluminum strips for the inside lip of the two so that the pop rivits wont be pulled thru the plastic.
epoxy the strips on and clamp
VS tip marked for cut
Rudder upper tip sanded for fit
Tips with the strips epoxied and clamped
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
