Brief Description: Finish preparing for fitting the wings
1. Drilled the hole on left side for the pitot tube to go through the fuse. Drilled it 5/16 for a bushing with a 1/4 ID and installed the bushing.
2. Set some very high tech wing supports on some harbor freight dollies which will have the wing about 1/2 inch lower than the opening. The idea is to not have to worry about moving the supports out of the way during the wing install
3. Put the right wing on the supports and applied a generous supply of bolube to the spar end and then rolled the wing into position.
4. Pulled the scat hose for the the wing air intake through the opening in fuse.
Drilled a 5/16 hole for a bushing with 1/4 ID for the pitot line
