Bill & Brendas RV-8 QB
RV-8
DWG 84
Baggage door lock install
1. Installed the lock in the baggage door as per plans
2. Installed the bushings and the slide pins in place. Attached with a clvis pin and then secured with safety wire.
3. Attached to the lock barrel with lock washer and screw
4. Checked for smoothe operation
Slide rods attached and secured with safety wire
Lock front with key. Operates smoothly
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
