Brief Description: front throttle spacers and windscreen suport
no pics today short stop at hangar after work. I put the windscreen support in position with out bolting to take pictures of gaps. i then put a couple bolts in each side and torqued to verify that the gaps close up with out over torquing the nuts.
I then cut 5 haf inch spacers from some delrin rod I had left over. These spacers will be drilled later for the longer AN3 bolts I ordered for the front throttle quadrant.
