Brief Description: Left tank fuel line and fuel pump to firewall line
1. Made a template with some flexable wire for the left wing fuel line. Made the required bends to 3/8 AT to match. Then some back and forth tweeking it. Installed the AN nut and sleeve and then flared the end. Installed the rubber grommet in fuse skin for the tube to exit to the wing.
2. Installed the bulkhead fitting in firewall where the fuel line will exit the fuselage to engine compartment.
3. Made template for the fuel line from electric fuel pump to firewall fitting, and then started the tedious exercise of bending to fit. This line resulted in 2 scrap pieces resulted but the third I eventually got to fit properly.
