1. Edge finished the seat ramp ribs and the seat ramps. Also edge finished the mid cabin covers and the left and right bulk head covers
2. Clecoed on the bulk head cover and then screwed on the rt console. match drilled #19 the console 2 holes to the rt bulk head cover. removed both and deburred the holes.
3 drilled all the plate nut rivit holes in all the previous mentioned pieces and then cleaned with naptha, scuffed with maroon scotch brite pads, cleaned off with soap and water then naptha.
4. Primered all the parts with 3 coats. Left bottom surfaces bare
5. Dimpled and or counter sunk where required all the plate nut rivit holes and then installed plate nuts with flush rivits.
Dimple the corner of seat ramp rib with the dimple vice grip
Plate nuts installed on back side of seat ramp
Bulk head cap rt side match drilled to console and plate nuted
