Brief Description: Fuel float bend and cut. Aileron control stop tabs
Measured 3 inches from float edge down rod, set up in vice for 90 degree bend. Both left and right tanks. Measued 3 more inches and cut off excess. Fit to fuel sender. Will check with 12 volt battery and ohm meter later on.
The aileron control stops are made from aluminum angle 1X1 stock and cut and shaped to size using full scale diagram. Holes were then centered and drilled on drill press. Edges and holes deburred and set aside for assembly.
