Finished going thru the wing instructions and noting items that need to be completed on the quick build wings.
Started with the aileron brackets. Prepared the brackets by drilling, countersinking, deburring, edge breaking and polishing, and priming surface to surface areas as per instruction.
Assembled the bracket halves with the bearing sandwiched betwen and rivited the numerous holes.
Aileron bracket assemblies
Using the hand squeezer to set rivits
2 of 4 aileron brackets ready to be attached to wing
