Bill & Brendas RV-8 QB
RV-8
elevator trim tab final assembly
Alinged trailing edge of elevator with trimtab and marked and clamped hinge to elevator.
Rivited the hinge to elevator spar and inserted hinge pin with tab, marked where to bend hinge pin, disassembled and bent the hinge pin
Reassembled and checked for any twist. looked good.
Drilled ends of trim tab skin, countersunk and rivited with blind rivits
Bent forward edge of bottom skin so that it clears the elevator spar through full range of travel
Forwardf hinge for trim tab positioned and drilled
Trim tab all clecoed up for riviting
Trim tab rivited as well as ends and piano hinge pin bent twice per plans
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
