Bill & Brendas RV-8 QB
RV-8
6-10 and dwg 4
elevator electric trim mount
Marked hole locations for trim servo mounting brackets and then drilled and rivited with flush rivits.
Attached the trim servo to bracket assembly and tested with 12 volt battery. It works!!
Checked for proper clearance along full range and then filed and sanded to fit.
Attached to skin and reinforcement plate and double check fit.
I spent quite a bit of time looking at plans and laying out the lines before drilling.
Pitch trim servo installed
Trim servo mounting plate bottom view
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
