Bill & Brendas RV-8 QB
RV-8
Left elevator-1
Cleco up the lead counter weight to ribs and counter weight skin, drill screw hole to #12
Deburr skeleton edges
Mark, cut, and file lead counter weight to proper demension
Dimple and counter sink the trim tab spar
Bevel the edges of counter weight skin
Cleco everthing together and match drill the skin to understructure then disassemble and deburr drill holes
Final drill elevator horn to spar and rib root
Work on trim servo access cover and brackets
managed to mess up the trim access reinforcement plate. Needs to be drilled out and replaced. will order from van"s tomorrow
L elevator clecoed up
Trim tab spar-counter sunk hinge side, dimple the other side
Trim servo mounting bracket
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
