Deburr and edge finish the stiffiners for left side Cleco in the stiffiners on both left and right elevators Final drill all stiffiners and the trim motor plate to skins Deburr rivit holes Dimple stiffiners, deburr and polish, dimple and polish trim motor plate Scuff inside skins along rivit rows for primer as well as the stiffiner flanges. Cleaned with Naphtane and then prime with self etching duplicolor primertrim Dimple skins Back rivit in the stiffiners inside the left and right skins Rivit in the trim acess reinforcement plate on bottom of left skin
Note: The trim access plate should have had the nut plates rivited on before riviting on the access plate. Plans didn't say to do it but I guess I should have known.
