Dimple a hole in the leading edge on tip that was missed and and not dimpled. Required a special dimple plier and a thin no hole ypke to dimple and then set the rivit. Torque wrenc arrived as well and so I torqued the 4 nuts on the center hinge to 25 inch pounds and marked with some torque seal.
