Rivit front spars together with angle bars 810 and 814 Rivit nose rib, main rib and tip rib to front left spar. Rivit left HS skin top and bottom to spar and ribs
Note: 3 rivits were unacceptable.These were drilled out. The tip rib rivit bent the flange out and the enlarged upon drilling out. Van's said it was fine to use a larger pop rivit in its place.
