Clecoe and match drill the rear HS with the spar reinforcement bars. Match drill hinge brackets to the spar. center hinge bracket match drilled to eachother and to spar. bearing was placed between bracket halves and rivited. Marked all piece location and positions, dissassembled, deburred. Started working on front HS spar Marked angle bars for cut and radius and cut with hack saw. Filed to size and polished. Bent ends of angle reinforcement bars of front HS spar to 6 degrees using vice and wood block
Note: all time logged here for this day. other pages for pics only
Front HS angle bars put back to back to show equal bends
