Air Camper Construction Log
Date:  9-19-2009
Number of Hours:  2.50
Brief Description:  Wing Rib LE/TE Sanding/Grooving
I chose a rib that I thought was as close to ideal as possible... overall length, LE angle and TE measurements. I used it as a template to shape, or fine tune (where necessary) on the other ribs. Very little shaping was necessary as all were nearly identical, but I am hoping the extra effort will show when the wing is fully assembled by reducing the wavy look and keep things looking square.
I also set up a simple jig on the table saw in order to cut a groove in the TE of my wing ribs. i am going tpo use the tongue and groove techique for attaching my TE.
