Air Camper Construction Log
Date:  9-8-2011
Brief Description:  Vacuum Bagging System
Finished up work on the vacuum bagging system. Built a reservoir to act as a buffer and smooth out the delivery. I also added a bleed valve, which allows me to regulate the vacuum. The system pulls down to ~24"Hg, which is equvilent to 12psi of clamping pressure. The valve allows adjustment from 0" - 24".
