Air Camper Construction Log
Date:  5-4-2010
Brief Description:  Installed Drag/Anti-Drag Cables
Installed drag/anti-drag cables and set tension to 150psi. I found that the cables I installed in the left wing panel had relaxed to ~125psi, so I set these a little high as well in order to allow for the same result. I'll check all of these again down the road, before final assembly, to ensure they are balanced.
I also installed the aileron spar.
