Brief Description: Inspection plate nutplates and tie down assembly
Drilled out attachment holes for K1000-6 plate nuts and counter sunk. Counter sunk #6 holes. Primed all counter sunk holes and riveted plate-nuts to spar flange. Cut tie down assembly plates to sized. Drilled our all holes per instructions using the spar web as guide. Drilled holes for plate-nuts and counter sunk holes. Set assembly aside tool for tapping hole for tie down ring.
