Filed off tooling marks on edges of rear spars and doubler plates. Started fitting doubler plates and match drilling. Use vixen files to remove tooling marks. For the first time, use die grinder and scotch bright wheels to clean-up and round off edges. Process went more quickly than using the file and scotch bright pads, the method I used on the empennage spars.
