Brief Description: Completed the Horiz Trim Fin Assembly for the Co-p
Regarding the technical question I had where my measurement between the face of bulkhead #3 and the center of the Trim Fin support tubes was 6 1/4" instead of the 5 3/4" called out by the blue print, I called the factory and learned the following: Mark Johnson advised that this is not a problem because what IS important is the 1/4" belt clearance. To help achieve this, they have moved the Horiz. Trim Fins slightly forward, but they have not kept their drawings updated.I assembled, drilled, screwed & glued the Co-pilot side Winglet to the Horizontal Trim Fin.
Getting ready to mate the Winglet to the Horiz. Trim Fin
