Jeff & Jackie's RV-8 Project
Date:  7-18-2008
Manual Reference:  n/a
Brief Description:  Right side console mod
Yet another mod! This time, the right-side console. I plan to put switches and circuit breakers on the right side console, and mounted against the skin will be a terminal block for the front and rear Infinity stick grip wiring. Obviously I didn't want the terminal block in plain sight, so I made a screw on cover to close the area in. It is simply held in place with #8 screws top and bottom. The top screws go into the existing console (obviously) and the lower ones into a piece of .063" angle riveted to the bottom cover plate. Rather than trim the stiffening bend from the existing console I left it in place so it still provides some stiffness.
