Jeff & Jackie's RV-8 Project
Date: 9-30-2007
Number of Hours: 1.00
Manual Reference: 8-36
Brief Description: Cockpit fuel system
Spent the day at home again today thanks to the weather (no jumping for me). Even so, and despite not really doing much else, today wasn't really an airplane day. I just couldn't really get into it, and I long since learned that when that happens, I make mistakes if I force myself.
So anyway, the sum total of my work was one additional line: the fuel return line to the left wing tank. Since I don't actually have a return line fitting on the tank, I had to kind of 'guesstimate' a location and run teh line accordingly. I left a good length of line sticking out of the side of the fuselage so hopefully I have plenty to work with. My previously made side skin template worked great here, and I will later on transfer the fuel return line hole into the side skin itself using the template.
Ah, no actually, the other thing I did today: I bought some clear nylon plastic tube and used it to protect the vent line in the left gear tower. No photo, but I'll get one of the right side when I do that. It was a bit of a sod to get on to the already bent line, but a little lubrication and I worked it slowly into place. I feel a little happier that the line is less likely to have a problem with vibrating and chafing against the gear tower.
Left side fuel return line
Left side fuel return line through the skin template
