Made up the right-side vent tube and installed into the gear tower. As with the left side, I put some plastic tube over the vent pipe to guard against abrasion in the gear tower. All I need to do now is cut the fuel return hole into the right-hand side skin and then I can install that skin on. I can't make the fuel line or return line until some new tube arrives from Vans.
