I got the canopy frame back from the painters but before re-fitting it to the fuselage I decided to finish the trimming of the rear seat throttle holes in the center section bulkheads. I did that and then cleco'd the bulkhead cover in place. I reached through one side with a pen to mark the enlarged hole in the bulkhead onto the cover. I then removed the cover and opened the hole. Re-fit and same again to do the other side, and quick set to with a sanding drum on the dremel and that's done. Finally, I lengthened the slot for the rear throttle lever since I had noticed it was restricting the movement of the front lever when it was all assembled. Next, canopy frame...
