Jeff & Jackie's RV-8 Project
Date:  8-1-2008
Number of Hours:  0.75
Manual Reference:  n/a
Brief Description:  Stick wiring
This is how I intend to connect the stick wiring. I have this length of AMP terminal strip and have fixed it to a bracket I made up. This will be riveted to the side skin under the right-side switch console. Both sticks will be wired into this block onto the piggy- back 'fast-on' tabs with grounds commoned together and screwed to the airframe at the gear tower.
