Brief Description: Build and Test Post-Curing Oven
Build and Test Post-Curing Oven. Heated with a single hair dryer only raised the temperature to 110 degrees, while I was trying for 120 degrees, heating for 6 hours. I added a second hair dryer but that blew the circuit breaker in the basement. After skinning the upper surface, I'll build the oven again and either run an extention cord from an outlet on a different circuit or extend the time in the oven.
