Brief Description: Finish layup of lower right wing attach bolt acces
Finish layup of lower right wing attach bolt access port. I added flox around the edge of the port where it abutted the shear web after removing a small triangle of foam. I then added micro to even out the pits in the foam, and then added one layer of BID and wetted it out with epoxy.
