Brief Description: Successfully hotwire FC-2, FC-3, FC-11 and FC-12 W
Successfully hotwire FC-2, FC-3, FC-11 and FC-12 Wing core. These are the largest cores that need to be cut. New saw, new thinner wire, and main power supply. The old power supply was faulty giving over and under voltage within a single cut causing wire lag and excessive melting. Not a problem with these cores.
