I fitted the Turtle Deck by trimming out material so it would fit around the head rack tube. I did not trim out material for the Aileron and Flap cables. I’ll wait to do that after the wings are mounted and the cables are installed. I installed #8 nut plates on the mounting tabs and mounted the assembly in place. I also drilled mounting holes for the Com antenna and Beacon Light.
