I installed the main landing gear. That took quite a bit of fitting to get the bolts into the attachment bushings. I’m going to have to fiddle with that some more so the bolts will go through smoothly. I used rope instead of the bungies. I'm going to remove the gear for painting so there's no need to put the bungies on yet.
I also fitted and drilled the plate that supports the fuel valve.
