Brief Description: Installation of Fuel lTank (cont'd)
Continuing on with the Checkoway method. Tightened up the tank/leading edge joint with straps. Drilled the inboard z-bracket using the angle drill. Could not find my 12" drill unfortunately. Need to remove the leading edge assembly to drill outboard next, but that's going to require a mod to my wing-stand. Will tackle that on Friday.
