Brief Description: Horizontal Stabalizer - Right Side
Very productive night. Repeated Horizontal Stablizer steps for right side, similar to the left. Went fairly quickly...it helps having been there before. Final drilled skin on both sides using #40 drill. Angle drilled 404-702-405 flanges. Just barely made the min. edge distance on HS-404. Sitting right at .25 inch so it's in spec. Finished the evening by removing the plastic where the rivets will be. Must do the same on the left side skin next session.
