Jeff Mitchell's RV8 project
Date:  3-9-2011
Number of Hours:  3.00
Manual Reference:  N/A
Brief Description:  Ground busses, master and start relays - Part 2.
I installed a terminal strip that I will use as an avionics grounding bus. I installed ground wires connecting the firewall ground to the left and right hand upper longerons. These longerons run the entire length of the airplane and make a good spot to ground electrical components.
Master and start relays
Avionics ground bus
Avionics ground bus
Ground wire
Ground wire
