Jeff Mitchell's RV8 project
Date:  3-12-2011
Number of Hours:  3.00
Manual Reference:  N/A
Brief Description:  Ground busses, master and start relays - Part 3.
I fabricated a brass strip that gangs all the No. 6 threaded posts together that will be used for grounding avionics. I ran No. 14 AWG in a twisted pair from the boost pump to the VP-50 CU and a ground bus on the right hand longeron.
Fuel boost pump wired
Avionics ground bus
Avionics ground bus
