Jeff Mitchell's RV8 project
Date:  3-7-2011
Number of Hours:  4.50
Manual Reference:  N/A
Brief Description:  Ground busses, master and start relays - Part 1.
I removed the primer on the left and right hand upper longerons in preparation for mounting the ground busses. I used some Dow Corning Compound 4 between the mating surfaces and used Cherry Max structural rivets to install them. I wired up the master and starter switches, hooked up the battery and checked that both relays closed properly.
Longeron surface prepared
Ground buss installed
Master switch wired
Master switch wired
