Jeff Mitchell's RV8 project
Date:  11-29-2010
Number of Hours:  5.00
Manual Reference:  N/A
Brief Description:  Dynon remote compass - Part 1.
I worked on installing the Dynon remote compass in the tail section today. I have already fabricated a shelf support at the rear of the fuselage away from any magnetic interference. The remote compass needs to be installed within 1 degree of pitch of the D-100 EFIS unit (which is installed in the main instrument panel). I used my digital level to determine the compass needs to be tilted forward by 6 degrees to accomplish this. I fabricated some shims out of Delrin which should do the trick. I need to use the shear at work to cut a base out of thicker aluminum than what I used for the first attempt. More on this in a future build log.
Delrin shims
Delrin shims
Temporary rivets in place
