Brief Description: Installed right hand fuel tank.
I installed the right hand fuel tank and fastened the screws to the spar and the inboard edge of the leading edge assembly. I started from the top and bottom leading edge and moved aft alternating both sides. I got a pretty nice joint between the tank and leading edge assembly. All my AN3-4A bolts went in no problem (all lined up) and torqued them to 25 in/lbs then applied torque sealant.
