Brief Description: Clecoed on the right wing top skins.
I clecoed the top skins to the right wing under structure. The rivet holes along the joint of the in and outboard skins were off just a hair. I knew this must have been from the way sequence I inserted the cleco’s because the skins have been on several times before with perfect alignment. I checked the main spar for trueness then re-installed the skins from the main spar working across then down. This fixed the alignment and I'm ready for riveting next time Sean gets a free day to help.
