I removed the clamping blocks and made a slight modification in preparation for bending the remaining tab down. I cut a slight taper in the side of the block to allow me to bend the first tab a bit beyond 90 degrees. This allowed the remaining tab to lay flat over the first. I used less double sided tape and took my time completing the top tab downward bend. Turned out well, and is better than my Trim Tab attempt number one.
