Brief Description: Clamped and bent the bottom tab up.
Using the same clamping blocks I fabricated and used for Trim Tab attempt number one I had no problem bending the bottom tab up using the method described in the construction manual. I used double sided tape between the table and blocks and between the skin and blocks. I used more than I needed and it was a pain removing it. (On Trim Tab attempt number 3 I will use far less!)
